Introducción
A common problem on the Canon EOS A2 is for the pop up flash mechanism to get stuck and not "pop-up". This is caused by the camera fooling itself into thinking an external flash is installed, which interferes with the main flash.
Herramientas
Partes
No se requieren partes.
Locate the battery door/camera grip on the left side of the camera and lift the rotating removal tab.
The inside of the flash shoe has a removable cover which is just snapped in place.
Using the flathead screwdriver, pry up on the front end of the cover.
Warning: The cover is on tight and is tough to pry off.
