Saltar al contenido principal
Fairphone 1 Battery Replacement
Qué necesitas
  1. Fairphone 1 Battery Replacement, Back Cover: paso 1, imagen 1 de 3 Fairphone 1 Battery Replacement, Back Cover: paso 1, imagen 2 de 3 Fairphone 1 Battery Replacement, Back Cover: paso 1, imagen 3 de 3
    • There is a small indentation in the side of the phone near the bottom of the back cover.
    • With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone.
  2. Fairphone 1 Battery Replacement: paso 2, imagen 1 de 3 Fairphone 1 Battery Replacement: paso 2, imagen 2 de 3 Fairphone 1 Battery Replacement: paso 2, imagen 3 de 3
    • Slide the back cover down and remove it from the phone.
  3. Fairphone 1 Battery Replacement, Battery: paso 3, imagen 1 de 3 Fairphone 1 Battery Replacement, Battery: paso 3, imagen 2 de 3 Fairphone 1 Battery Replacement, Battery: paso 3, imagen 3 de 3
    • There is a small indentation in the back of the phone just below the battery.
    • Use a fingernail in this indentation to push the battery toward the top of the phone
    • Pull the battery out away from the phone.
  4. Fairphone 1 Battery Replacement: paso 4, imagen 1 de 1
    • Remove the battery from your Fairphone.
Conclusión
4 personas más completaron esta guía.
Equipo
iFixit Miembro de iFixit
Staff
118 Miembros
19,455 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 8,941
