Saltar al contenido principal
Fahrenheit FHT 125PRMR Power Cord Replacement
Qué necesitas
  1. Fahrenheit FHT 125PRMR Power Cord Replacement, Power Cord: paso 1, imagen 1 de 1
    • Use your fingers or a plastic opening tool to open the side hinges on both sides of the device.
  2. Fahrenheit FHT 125PRMR Power Cord Replacement: paso 2, imagen 1 de 1
    • Using a Philips head #2 screwdriver remove the 7mm black screw from the hinge of the device.
  3. Fahrenheit FHT 125PRMR Power Cord Replacement: paso 3, imagen 1 de 2 Fahrenheit FHT 125PRMR Power Cord Replacement: paso 3, imagen 2 de 2
    • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
    • When the pin is removed the two sides of the device can now separate.
    • Be sure to collect the spring that is next to the hinge when they are separated.
  4. Fahrenheit FHT 125PRMR Power Cord Replacement: paso 4, imagen 1 de 2 Fahrenheit FHT 125PRMR Power Cord Replacement: paso 4, imagen 2 de 2
    • Use the Phillips Head 1 screwdriver to remove the two screws on the back where the power cable exits the device.
    • Once the two screws are removed; simply lift the case up and off to have access to the power cable.
  5. Fahrenheit FHT 125PRMR Power Cord Replacement: paso 5, imagen 1 de 1
    • To remove the power cable, grab the clear plastic holding and the base of the power cable and pull apart.
Conclusión
4 personas más completaron esta guía.
Joshua Potts
Miembro Desde 09/29/16
265 Reputación
1 Guía escrita
Equipo
IUPUI, Team 2-2, Harley Fall 2016 Miembro de IUPUI, Team 2-2, Harley Fall 2016
IUPUI-HARLEY-F16S2G2
4 Miembros
4 Guías creadas
3 comentarios
Where do I find a new power cord? I've tried searching everywhere.
tmbrand04 - Contestar
Where do you buy the power cord?
Dominique - Contestar
probably available at electronic store
john john - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 2,458
