Saltar al contenido principal
Etón Scorpion Battery Replacement
Qué necesitas
  1. Etón Scorpion Battery Replacement, Battery: paso 1, imagen 1 de 3 Etón Scorpion Battery Replacement, Battery: paso 1, imagen 2 de 3 Etón Scorpion Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Your device should look like this.
  2. Etón Scorpion Battery Replacement: paso 2, imagen 1 de 1
    • Turn the unit on its side and look for this panel.
  3. Etón Scorpion Battery Replacement: paso 3, imagen 1 de 3 Etón Scorpion Battery Replacement: paso 3, imagen 2 de 3 Etón Scorpion Battery Replacement: paso 3, imagen 3 de 3
    • Unscrew this screw with a Phillips head #0 screwdriver.
    • Remove the panel.
  4. Etón Scorpion Battery Replacement: paso 4, imagen 1 de 3 Etón Scorpion Battery Replacement: paso 4, imagen 2 de 3 Etón Scorpion Battery Replacement: paso 4, imagen 3 de 3
    • Pull out the battery and disconnect the connector.
Conclusión
To reassemble your device, follow these instructions in reverse order, and remember to connect the connector when putting in a new battery.
Una persona más ha completado esta guía.
9021007
Miembro Desde 07/13/18
4,502 Reputación
25 Guías creadas
3 comentarios
What specific battery did you purchase to replace the original battery pack? My battery needs to be 1.25” by 1.25” to fit into the compartment. Many of the batteries I have found on Amazon that claim to be replacement are much larger an won’t fit into the compartment.
Mark Chapin - Contestar
https://www.amazon.com/South-33053-Cordl...
This battery seems to be a good fit. It says in the question and answer section that it’s 1.2"" x 1.15"x 0.42".
9021007 -
Need to switch the wire positions. What's the best way?
David - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 30
Todo El Tiempo: 951
