Introducción
If your Epson projector (model VS240) is experiencing display errors such as dark spots, missing regions, or focus issues, you can use this guide to replace the lens.
The lens is a key component of the projector that allows for images and video to be displayed, and a dirty lens or improper display settings can lead to display issues. Before choosing to replace the lens, check for and troubleshoot common display error issues.
Make sure to power off the projector and disconnect it from any external power sources before proceeding.
Qué necesitas
Using the Phillips #2 screwdriver, loosen the single captive screw on the left side of the projector.
Slide the panel off and remove it from the device.
Use a Phillips #1 screwdriver to remove two 10 mm screws from the openings on each side of the air filter, on the topside of the projector.
Using the same Phillips #1 screwdriver, remove the two 10 mm screws where the white panel was removed on the topside of the projector in Step 1.
Using a spudger or a plastic opening tool, disconnect all of the wires connected to the motherboard.
Rotate the projector 180 degrees to match orientation in images.
Using the Phillips #2 screwdriver, remove four inner 11 mm screws under the black box connected to the lens.
Una persona más ha completado esta guía.
