Saltar al contenido principal
Epson Stylus C84 Exterior Panel Disassembly
Qué necesitas
  1. Epson Stylus C84 Exterior Panel Disassembly, Removing the Back Panel: paso 1, imagen 1 de 2 Epson Stylus C84 Exterior Panel Disassembly, Removing the Back Panel: paso 1, imagen 2 de 2
    • Turn the printer around so the printer's front is facing away from you. Then, remove the rounded black panel from the paper guide by lifting it straight up.
    • Left Panel
    • Right Panel
    • Printer Front
    • Back Panel
  2. Epson Stylus C84 Exterior Panel Disassembly, Removing the "Parallel" Cover: paso 2, imagen 1 de 3 Epson Stylus C84 Exterior Panel Disassembly, Removing the "Parallel" Cover: paso 2, imagen 2 de 3 Epson Stylus C84 Exterior Panel Disassembly, Removing the "Parallel" Cover: paso 2, imagen 3 de 3
    • Wedge the flat end of the spudger between the top of the “Parallel” cover and the right panel, and gently pry the upper edge cover away. Completely remove the cover by hand if necessary. The Parallel and USB ports should be exposed.
  3. Epson Stylus C84 Exterior Panel Disassembly, Releasing the Prongs: paso 3, imagen 1 de 1
    • Next, turn the printer so that it's laying on its front side.
    • Locate the two plastic prongs on the bottom of the right panel.
    • Gently pinch the prongs together and push them with your fingers through the clips until they are free.
    • Do not use extreme force or bend the prongs in such a way that they break.
  4. Epson Stylus C84 Exterior Panel Disassembly, Pushing In the Interior Tabs: paso 4, imagen 1 de 3 Epson Stylus C84 Exterior Panel Disassembly, Pushing In the Interior Tabs: paso 4, imagen 2 de 3 Epson Stylus C84 Exterior Panel Disassembly, Pushing In the Interior Tabs: paso 4, imagen 3 de 3
    • Wedge a wide-tipped blue plastic opening tool inside the gray tab on the upper left-hand corner of the right panel, next to the arrow.
  5. Epson Stylus C84 Exterior Panel Disassembly, Releasing the Interior Tabs: paso 5, imagen 1 de 2 Epson Stylus C84 Exterior Panel Disassembly, Releasing the Interior Tabs: paso 5, imagen 2 de 2
    • Push in the gray tab until it becomes separated from the rest of the panel.
  6. Epson Stylus C84 Exterior Panel Disassembly, Holding the Right Panel in Place: paso 6, imagen 1 de 2 Epson Stylus C84 Exterior Panel Disassembly, Holding the Right Panel in Place: paso 6, imagen 2 de 2
    • Set the printer back down on its bottom.
    • Wedge one of the blue plastic separators between the back of the right panel and the rest of the printer’s housing to keep it separated.
  7. Epson Stylus C84 Exterior Panel Disassembly, Unclipping the Right Panel: paso 7, imagen 1 de 1
    • Turn the printer around so the front is facing toward you.
    • Open the printer’s cover, place your hand inside the right panel and unclip it from the rest of the printer with your thumb and forefinger.
    • Do not use extreme force when unclipping the panel.
  8. Epson Stylus C84 Exterior Panel Disassembly, Holding the Separated Right Panel: paso 8, imagen 1 de 1
    • Wedge a blue plastic separator between the plastic housing and the rest of the right panel and push the panel out from the inside to free it.
  9. Epson Stylus C84 Exterior Panel Disassembly, Removing the Right Panel: paso 9, imagen 1 de 1
    • Gently push the panel to the right to separate it from the printer.
  10. Epson Stylus C84 Exterior Panel Disassembly, Releasing the Ink Cartridge Carrier: paso 10, imagen 1 de 2 Epson Stylus C84 Exterior Panel Disassembly, Releasing the Ink Cartridge Carrier: paso 10, imagen 2 de 2
    • Use the flat end of the spudger to push the white button next to the ink cartridge carrier.
  11. Epson Stylus C84 Exterior Panel Disassembly, Manually Sliding the Ink Cartridge Carrier: paso 11, imagen 1 de 1
    • Gently slide the ink cartridge carrier by hand to the left to gain access to the inside of the left panel.
  12. Epson Stylus C84 Exterior Panel Disassembly, Removing the Left Panel's Prongs: paso 12, imagen 1 de 2 Epson Stylus C84 Exterior Panel Disassembly, Removing the Left Panel's Prongs: paso 12, imagen 2 de 2
    • Turn the printer so that it's on its front side again. Now there are two sets of prongs to undo for the left panel. Repeat step #2 for each set of prongs.
    • Do not use extreme force when removing the prongs.
  13. Epson Stylus C84 Exterior Panel Disassembly, Unclipping the Left Panel Upper Notch: paso 13, imagen 1 de 3 Epson Stylus C84 Exterior Panel Disassembly, Unclipping the Left Panel Upper Notch: paso 13, imagen 2 de 3 Epson Stylus C84 Exterior Panel Disassembly, Unclipping the Left Panel Upper Notch: paso 13, imagen 3 de 3
    • Wedge a blue plastic separator in the gray tab on the upper right-hand corner of the left panel.
    • Unclip the panel from inside the printer, and remove it.
  14. Epson Stylus C84 Exterior Panel Disassembly, Unclipping the Back Panel: paso 14, imagen 1 de 3 Epson Stylus C84 Exterior Panel Disassembly, Unclipping the Back Panel: paso 14, imagen 2 de 3 Epson Stylus C84 Exterior Panel Disassembly, Unclipping the Back Panel: paso 14, imagen 3 de 3
    • Turn the printer around so the front is facing away. Use three wide-tip blue plastic opening tools and place them inside the notches on the back panel of the printer.
  15. Epson Stylus C84 Exterior Panel Disassembly, Separating the Notches: paso 15, imagen 1 de 2 Epson Stylus C84 Exterior Panel Disassembly, Separating the Notches: paso 15, imagen 2 de 2
    • Push on each notch until the retaining tabs are separated from the back plastic cover.
  16. Epson Stylus C84 Exterior Panel Disassembly, Releasing the Tabs: paso 16, imagen 1 de 2 Epson Stylus C84 Exterior Panel Disassembly, Releasing the Tabs: paso 16, imagen 2 de 2
    • Turn the printer around so the front is facing you and gently push up on each tab of the front plastic panel, above the arrows. Make sure the prongs are detached from the clips.
  17. Epson Stylus C84 Exterior Panel Disassembly, Removing the Casing: paso 17, imagen 1 de 3 Epson Stylus C84 Exterior Panel Disassembly, Removing the Casing: paso 17, imagen 2 de 3 Epson Stylus C84 Exterior Panel Disassembly, Removing the Casing: paso 17, imagen 3 de 3
    • Gently pull the plastic housing upward to remove the back panel and reveal the inner components of the printer.
Conclusión
2 personas más completaron esta guía.
Equipo
UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2013 Miembro de UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G3
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 16
Todo El Tiempo: 1,124
