Saltar al contenido principal
Epson Powerlite 410W Lamp Replacement
Qué necesitas
  1. Epson Powerlite 410W Lamp Replacement, Lamp: paso 1, imagen 1 de 1
    • Press the power button located on top of the projector.
    • Remember to let the projector cool off completely after turning off the power before beginning the repair.
  2. Epson Powerlite 410W Lamp Replacement: paso 2, imagen 1 de 3 Epson Powerlite 410W Lamp Replacement: paso 2, imagen 2 de 3 Epson Powerlite 410W Lamp Replacement: paso 2, imagen 3 de 3
    • Loosen the single captive screw holding the lamp cover in place using a Phillips #2 screwdriver.
    • Slide the cover out, then lift it off and place to the side.
  3. Epson Powerlite 410W Lamp Replacement: paso 3, imagen 1 de 1
    • Loosen the two captive screws that hold the lamp in place using a Phillips #2 screwdriver.
  4. Epson Powerlite 410W Lamp Replacement: paso 4, imagen 1 de 1
    • Use your hands to pull the lamp straight out of the projector.
    • When inserting the new lamp, push the lamp down firmly, where the label “PUSH” appears.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 16
Todo El Tiempo: 258
