Introducción
If the fan in your Epson Powerlite 410W projector seems to be running very loudly, not working at all, or the temp light is flashing, you will most likely need to replace the fan. If you are unsure what is wrong with your device, please visit our troubleshooting page.
The fan is set in the projector below the lamp and lens. It helps to cool down the body of the projector when it is working hard so that it does not overheat. Before replacing the fan, make sure it cannot be fixed from just cleaning and re-greasing the fan.
Qué necesitas
Remove the two screws holding down the motherboard using a Phillips #00 screwdriver.
Remove the four screws holding down the I/O board using a Phillips #00 screwdriver.
Remove the screws that are holding the front cover in place.
Remove the white front cover by pulling it away from the lens.
Una persona más ha completado esta guía.
