Saltar al contenido principal
Ematic EGQ307 Speaker Replacement
Qué necesitas
  1. Ematic EGQ307 Speaker Replacement, Speaker: paso 1, imagen 1 de 2 Ematic EGQ307 Speaker Replacement, Speaker: paso 1, imagen 2 de 2
    • There are two screws on the side with the micro USB power port. Remove the two 2mm x 0.5mm screws with a Phillips #0 Screwdriver head.
  2. Ematic EGQ307 Speaker Replacement: paso 2, imagen 1 de 2 Ematic EGQ307 Speaker Replacement: paso 2, imagen 2 de 2
    • Pry off the plastic backing with the spudger and the plastic opening tools. Anything that can provide enough leverage and not conduct electricity will also work for this purpose.
    • Carefully separate the front and back plates because the wire that connects the speaker is connected to both the front and back plates.
  3. Ematic EGQ307 Speaker Replacement: paso 3, imagen 1 de 2 Ematic EGQ307 Speaker Replacement: paso 3, imagen 2 de 2
    • Once you pry off the plastic backing, you will expose the battery and the motherboard. Then remove the tape on the speaker wire.
  4. Ematic EGQ307 Speaker Replacement: paso 4, imagen 1 de 3 Ematic EGQ307 Speaker Replacement: paso 4, imagen 2 de 3 Ematic EGQ307 Speaker Replacement: paso 4, imagen 3 de 3
    • Carefully remove tapes holding speaker in place.
    • Disconnect the speaker wires from the motherboard.
    • When working with device, make sure the battery is dead and there is not plugged in to the charger to limit the risk of shock.
  5. Ematic EGQ307 Speaker Replacement: paso 5, imagen 1 de 2 Ematic EGQ307 Speaker Replacement: paso 5, imagen 2 de 2
    • Pry the speaker out of the plastic casing to replace it with the new speaker using the spudger.
    • If replacing the speaker, you will need a soldering kit to reconnect the wires with the new speaker after disconnecting the old speaker.
    • How To Solder and Desolder Connections.
Conclusión
To reassemble your device, follow these instructions in reverse order, note you will need to solder for this replacement.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 302
