Saltar al contenido principal
Inglés
Español
Traduciendo paso 5
Paso 5
Pry the speaker out of the plastic casing to replace it with the new speaker using the spudger. If replacing the speaker, you will need a soldering kit to reconnect the wires with the new speaker after disconnecting the old speaker.
  • Pry the speaker out of the plastic casing to replace it with the new speaker using the spudger.
  • If replacing the speaker, you will need a soldering kit to reconnect the wires with the new speaker after disconnecting the old speaker.
  • How To Solder and Desolder Connections.
Insertar traducción aquí
