Saltar al contenido principal
Element GC-1020 Screen Replacement
Qué necesitas
  1. Element GC-1020 Screen  Replacement, Back Cover Replacement Guide: paso 1, imagen 1 de 1
    • Unscrew the four screws (size: 3.175mm) on the left and right side of the Element Electronics GC-1020 device using the PH#0 screwdriver.
  2. Element GC-1020 Screen  Replacement: paso 2, imagen 1 de 1
    • Carefully pull the back of the device (the silver portion) apart from the rest of the device.
    • If you pull back too forcefully the power button would move out of place.
  3. Element GC-1020 Screen  Replacement, Screen: paso 3, imagen 1 de 1
    • Unscrew the bottom of left and right sides of the motherboard.
    • Notice these screws are slightly larger than the ones on the outside of the device.
  4. Element GC-1020 Screen  Replacement: paso 4, imagen 1 de 2 Element GC-1020 Screen  Replacement: paso 4, imagen 2 de 2
    • Carefully bend the plastic frame to remove the motherboard.
    • Be sure that the power button, stays attached to the outer frame, as moving the motherboard it may cause it to loosen.
  5. Element GC-1020 Screen  Replacement: paso 5, imagen 1 de 3 Element GC-1020 Screen  Replacement: paso 5, imagen 2 de 3 Element GC-1020 Screen  Replacement: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Detach the screen by disconnecting the thin piece of ribbon cable attached to the PCB (printed circuit board).
    • Use a pair of tweezers to carefully pull the ribbon from the circuit board.
    • Take care not to damage the ribbon, as you will need it intact to reattach your new screen.
  6. Element GC-1020 Screen  Replacement: paso 6, imagen 1 de 3 Element GC-1020 Screen  Replacement: paso 6, imagen 2 de 3 Element GC-1020 Screen  Replacement: paso 6, imagen 3 de 3
    • Carefully pry apart the screen from the frame of the device.
    • Separate the two by peeling away the thin plastic layer that makes up the screen of the device.
    • If done correctly, your detached screen will look like this.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 10
Todo El Tiempo: 231
