Introducción
This guide demonstrates how to remove or replace the left lower feeder assembly in the auto-feeder on your Electric Eel 75’ Drain Cleaner Z5K12IC75AF.
If you need to remove or replace the right lower feeder assembly, simply perform steps 12-17 on the opposite side of the feeder body.
Qué necesitas
Twist the guide spring counter-clockwise to unscrew it from the auto-feeder.
Remove the guide spring.
Unscrew the tension knob to loosen the tension spring in the top feeder assembly.
Set the feeder adjustment knob in the neutral position, in between the "FWD" and "REV" positions.
Use a 1/2" open-ended wrench to remove the two bolts from the bottom of the feeder body mounting arm.
Use a vise to compress the roll pin until there is no longer space in the roll pin's slot.
Use a pair of snap ring pliers to remove the retaining ring at the bottom of the lower feeder assembly.
Use a pair of needle-nose pliers to remove the first thrust washer from the assembly.
Use a flathead screwdriver to remove the lower control finger from the assembly.
Use a flathead screwdriver or other long tool as leverage to remove the lower bearing carrier from the assembly.
After reassembly: Ensure the assembly you just installed is sufficiently lubricated using the Zerk fitting on the feeder body.
Una persona más ha completado esta guía.
