Saltar al contenido principal
Eleaf iJust 3 Disassembly
Qué necesitas
  1. Eleaf iJust 3 Disassembly, Eleaf iJust 3 Teardown: paso 1, imagen 1 de 1
    • Specification of iJust 3:
    • Resistance range: 0.1 Ohm - 3.0 Ohm
    • Battery voltage: 3.7V
    • Max power: 80W
  2. Eleaf iJust 3 Disassembly: paso 2, imagen 1 de 2 Eleaf iJust 3 Disassembly: paso 2, imagen 2 de 2
    • Insert stick into vice (attach it to the top part) and slowly pull up by "tube part"
    • Be carefull! If you will pull it too fast and too strong, you can break away battery
  3. Eleaf iJust 3 Disassembly: paso 3, imagen 1 de 1
    • Unscrew two screws on the sides of board.
  4. Eleaf iJust 3 Disassembly: paso 4, imagen 1 de 1
    • Thats all, thanks for your attention
Linea de Meta
5 personas más completaron esta guía.
Szymon Milewski
Miembro Desde 12/28/20
741 Reputación
3 Guías creadas
2 comentarios
It was very helpful, thank you!
kali1902 - Contestar
I don’t think Ifixit should be hosting repair guides for products that can damage your health.
guardian10 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 17
Ultimos 30 días: 54
Todo El Tiempo: 4,933
