Introducción
Follow this guide to replace a damaged arbor assembly on the Edco Cement Saw KL1465H.
Qué necesitas
Disconnect the spark plug to prevent the engine from accidentally starting up during service:
Grab the plastic spark plug cap at the end of the spark plug wire.
Firmly pull to disconnect the spark plug cap from the spark plug.
To prevent the concrete saw from rolling during service, place wheel chocks in front of and behind a rear wheel.
Use a 3/8-inch wrench to remove the two bolts securing the arbor guard.
Remove the arbor guard.
Use a 3/8-inch wrench to remove the two bolts securing the belt guard.
Remove the belt guard.
Un comentario
I'd really like to see this type of guide done on a machine that has been USED by say rental customers! I do appreciate the guides but they are somewhat unrealistic because everything is new. Also, I didn't see a part number for a whole and assembled arbor. That would be nice to have.
