Saltar al contenido principal
Ecovacs Deebot 900 Wheel Replacement
Qué necesitas
  1. Ecovacs Deebot 900 Wheel Replacement, Battery: paso 1, imagen 1 de 1
    • Remove all the brushes from the Deebot.
  2. Ecovacs Deebot 900 Wheel Replacement: paso 2, imagen 1 de 1
    • Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.​
  3. Ecovacs Deebot 900 Wheel Replacement: paso 3, imagen 1 de 1
    • Remove the battery cover.
  4. Ecovacs Deebot 900 Wheel Replacement: paso 4, imagen 1 de 1
    • Using the two white straps on the sides of the battery, gently remove the battery. ​
    • Be careful not to rip out the battery cable.
  5. Ecovacs Deebot 900 Wheel Replacement: paso 5, imagen 1 de 1
    • Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
  6. Ecovacs Deebot 900 Wheel Replacement, Front Bumper: paso 6, imagen 1 de 2 Ecovacs Deebot 900 Wheel Replacement, Front Bumper: paso 6, imagen 2 de 2
    • Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper. ​
  7. Ecovacs Deebot 900 Wheel Replacement: paso 7, imagen 1 de 1
    • Remove the black strip on the bottom of the bumper.
  8. Ecovacs Deebot 900 Wheel Replacement: paso 8, imagen 1 de 2 Ecovacs Deebot 900 Wheel Replacement: paso 8, imagen 2 de 2
    • Carefully lift up the bumper untill it pops out of place.​
  9. Ecovacs Deebot 900 Wheel Replacement: paso 9, imagen 1 de 2 Ecovacs Deebot 900 Wheel Replacement: paso 9, imagen 2 de 2
    • Disconnect the two cables connecting the bumper to the body of the Deebot.
    • Remove the front bumper from the device.
  10. Ecovacs Deebot 900 Wheel Replacement, Bottom Case: paso 10, imagen 1 de 2 Ecovacs Deebot 900 Wheel Replacement, Bottom Case: paso 10, imagen 2 de 2
    • Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
  11. Ecovacs Deebot 900 Wheel Replacement: paso 11, imagen 1 de 2 Ecovacs Deebot 900 Wheel Replacement: paso 11, imagen 2 de 2
    • Insert a Jimmy into the seam and work all the way around the robot.
    • Disconnect the two cables and remove the bottom case from the device.
  12. Ecovacs Deebot 900 Wheel Replacement, Motherboard: paso 12, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove the two black screws holding the motherboard in place.​
  13. Ecovacs Deebot 900 Wheel Replacement: paso 13, imagen 1 de 1
    • Carefully remove the ribbon cables connected to the top of motherboard.
    • Keep track of where the cables connect to the motherboard.
  14. Ecovacs Deebot 900 Wheel Replacement: paso 14, imagen 1 de 1
    • Remove the last three ribbon cables on the underside of the motherboard.​
  15. Ecovacs Deebot 900 Wheel Replacement: paso 15, imagen 1 de 1
    • Lift the motherboard out of the Deebot and remove it from the device.
  16. Ecovacs Deebot 900 Wheel Replacement, Wheel: paso 16, imagen 1 de 1
    • Using a screwdriver or tweezers, remove the spring by lifting the spring and pulling it off one side.
  17. Ecovacs Deebot 900 Wheel Replacement: paso 17, imagen 1 de 2 Ecovacs Deebot 900 Wheel Replacement: paso 17, imagen 2 de 2
    • Using a Phillips #00 screwdriver, remove the four screws holding the wheel assembly in place.
  18. Ecovacs Deebot 900 Wheel Replacement: paso 18, imagen 1 de 1
    • Remove the wheel cover.
  19. Ecovacs Deebot 900 Wheel Replacement: paso 19, imagen 1 de 3 Ecovacs Deebot 900 Wheel Replacement: paso 19, imagen 2 de 3 Ecovacs Deebot 900 Wheel Replacement: paso 19, imagen 3 de 3
    • Using the Phillips #00 screwdriver, remove the three screws holding the side brush motor in place and lift the brush motor up.
  20. Ecovacs Deebot 900 Wheel Replacement: paso 20, imagen 1 de 2 Ecovacs Deebot 900 Wheel Replacement: paso 20, imagen 2 de 2
    • Lift up and remove the wheel assembly and the attached sensor (black cable).
Conclusión
6 personas más completaron esta guía.
6 comentarios
Thanks, it helps a lot
Agoston David - Contestar
I have an OZMO 930 that the left driver wheel is stuck. I tried to follow the above instruction, but I can’t go beyond step 10, I can’t take out the cover. Any help will be greatly appreciated,
OldManInChicago - Contestar
do you have place to buy ecovac_deebot_900_54_gear ?? I thinking on printing it but after my printed gear to papper shreder I have no hopes it will last.
Plewu Gracz - Contestar
Thanks for the guide on the Deebot 900 wheel replacement. Though it has partially helps to resolve the problems, but unable to find a wheel replacement. Hope you can help too.
wong CS - Contestar
The rubber tires on my Deebot have worn through. Does anybody have a source for rubber tire replacement? The company wants to sell me two entire wheel assemblies. I find that unreasonable.
akobelan - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 31
Ultimos 7 días: 185
Ultimos 30 días: 727
Todo El Tiempo: 42,818
