Saltar al contenido principal
Ecovacs Deebot 900 Bottom Case Replacement
Qué necesitas
  1. Ecovacs Deebot 900 Bottom Case Replacement, Battery: paso 1, imagen 1 de 1
    • Remove all the brushes from the Deebot.
  2. Ecovacs Deebot 900 Bottom Case Replacement: paso 2, imagen 1 de 1
    • Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.​
  3. Ecovacs Deebot 900 Bottom Case Replacement: paso 3, imagen 1 de 1
    • Remove the battery cover.
  4. Ecovacs Deebot 900 Bottom Case Replacement: paso 4, imagen 1 de 1
    • Using the two white straps on the sides of the battery, gently remove the battery. ​
    • Be careful not to rip out the battery cable.
  5. Ecovacs Deebot 900 Bottom Case Replacement: paso 5, imagen 1 de 1
    • Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
  6. Ecovacs Deebot 900 Bottom Case Replacement, Front Bumper: paso 6, imagen 1 de 2 Ecovacs Deebot 900 Bottom Case Replacement, Front Bumper: paso 6, imagen 2 de 2
    • Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper. ​
  7. Ecovacs Deebot 900 Bottom Case Replacement: paso 7, imagen 1 de 1
    • Remove the black strip on the bottom of the bumper.
  8. Ecovacs Deebot 900 Bottom Case Replacement: paso 8, imagen 1 de 2 Ecovacs Deebot 900 Bottom Case Replacement: paso 8, imagen 2 de 2
    • Carefully lift up the bumper untill it pops out of place.​
  9. Ecovacs Deebot 900 Bottom Case Replacement: paso 9, imagen 1 de 2 Ecovacs Deebot 900 Bottom Case Replacement: paso 9, imagen 2 de 2
    • Disconnect the two cables connecting the bumper to the body of the Deebot.
    • Remove the front bumper from the device.
  10. Ecovacs Deebot 900 Bottom Case Replacement, Bottom Case: paso 10, imagen 1 de 2 Ecovacs Deebot 900 Bottom Case Replacement, Bottom Case: paso 10, imagen 2 de 2
    • Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
  11. Ecovacs Deebot 900 Bottom Case Replacement: paso 11, imagen 1 de 2 Ecovacs Deebot 900 Bottom Case Replacement: paso 11, imagen 2 de 2
    • Insert a Jimmy into the seam and work all the way around the robot.
    • Disconnect the two cables and remove the bottom case from the device.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 32
Todo El Tiempo: 2,544
