Introducción
This guide shows how to remove and replace the flexible driveshaft (flex shaft) in an Echo SRM-2620U Brushcutter.
This procedure can also be used to access and re-grease the existing flex shaft. This device requires 15 ml (1/2 oz) of lithium-based grease.
Qué necesitas
Grip the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
Use a T30 Torx driver to remove the locating screw from the gear case.
Use a T30 Torx driver to loosen, but not remove, the collar screw securing the main shaft to the gear case.
Grip the flex shaft and pull to remove it from the shaft housing.
Una persona más ha completado esta guía.
