Saltar al contenido principal
EVGA x17 Programmable Buttons Replacement
  1. EVGA x17 Programmable Buttons Replacement, Programmable Buttons: paso 1, imagen 1 de 1
    • Remove the mouse skates to reveal 5 screws.
  2. EVGA x17 Programmable Buttons Replacement: paso 2, imagen 1 de 1
    • Use a Phillips head screwdriver to remove the 5 screws that secure the bottom panel.
  3. EVGA x17 Programmable Buttons Replacement: paso 3, imagen 1 de 1
    • Remove the weight chamber cover.
  4. EVGA x17 Programmable Buttons Replacement: paso 4, imagen 1 de 1
    • Slowly slide a spudger into and around the bottom of the panel, prying until a "popping" sound is heard.
  5. EVGA x17 Programmable Buttons Replacement: paso 5, imagen 1 de 2 EVGA x17 Programmable Buttons Replacement: paso 5, imagen 2 de 2
    • Remove the 13 screws on the interior.
    • There are 2 Phillips truss-head tapping screws, large circular heads, and the 11 Phillips screws from the interior.
  6. EVGA x17 Programmable Buttons Replacement: paso 6, imagen 1 de 1
    • Carefully slide the middle section out.
  7. EVGA x17 Programmable Buttons Replacement: paso 7, imagen 1 de 2 EVGA x17 Programmable Buttons Replacement: paso 7, imagen 2 de 2
    • Remove screws from each button.
    • Press inwards and pop each button out of their socket.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 52
