Saltar al contenido principal
Dyson V8 Animal Brush Bar Replacement
Qué necesitas
  1. Dyson V8 Animal Brush Bar  Replacement, Brush Bar: paso 1, imagen 1 de 1
    • Push the red button and then slide the brush head off of the shaft.
    • The shaft must be held from moving when sliding the brush head off.
  2. Dyson V8 Animal Brush Bar  Replacement: paso 2, imagen 1 de 3 Dyson V8 Animal Brush Bar  Replacement: paso 2, imagen 2 de 3 Dyson V8 Animal Brush Bar  Replacement: paso 2, imagen 3 de 3
    • Insert a coin into the slot on the side of the brush head.
    • Turn the coin counter clock wise to unlock the brushbar.
    • Pull the brushbar straight out of the brush head.
    • Clean all debris off of the brushbar and from inside the brush head.
    • The brushbar will spring outwards slightly when unlocked successfully.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team S19-G1, White Winter 2020 Miembro de Cal Poly, Team S19-G1, White Winter 2020
CPSU-WHITE-W20S19G1
4 Miembros
10 Guías creadas
4 comentarios
Did that but brush still will not spin.
walt.florence - Contestar
I can't remove the brush, it springs outwards but keep firmly attached to the "axis". I've also tried to remove the transparent cover, by removing all the screws I've found on it (6 in total) but seems impossible. Can anyone please post a step by step guide about how to dissemble the whole brush bar??
Henar Lanchas López - Contestar
I’m saving my Pennys for the “coin tool”. It does seem hauntingly familiar however….
Enrico Crocetti - Contestar
I am unable to insert a coin into the slot provided. No problem previously
Mgt trotter - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 31
Ultimos 30 días: 135
Todo El Tiempo: 4,937
