Saltar al contenido principal
Dyson V8 Animal Battery Replacement
Qué necesitas
  1. Dyson V8 Animal Battery Replacement, Bin: paso 1, imagen 1 de 2 Dyson V8 Animal Battery Replacement, Bin: paso 1, imagen 2 de 2
    • Push the red button and slide the connecting shaft off.
    • The shaft must be held from moving when disconnecting from the motor.
  2. Dyson V8 Animal Battery Replacement: paso 2, imagen 1 de 3 Dyson V8 Animal Battery Replacement: paso 2, imagen 2 de 3 Dyson V8 Animal Battery Replacement: paso 2, imagen 3 de 3
    • Pull up on the red tab and continue to slide the motor completely up.
    • The dust bin will open on the bottom.
  3. Dyson V8 Animal Battery Replacement: paso 3, imagen 1 de 2 Dyson V8 Animal Battery Replacement: paso 3, imagen 2 de 2
    • Push the red tab down.
    • Pull the dust bin out from the handle head.
  4. Dyson V8 Animal Battery Replacement, Battery: paso 4, imagen 1 de 2 Dyson V8 Animal Battery Replacement, Battery: paso 4, imagen 2 de 2
    • Push down on the red tab.
  5. Dyson V8 Animal Battery Replacement: paso 5, imagen 1 de 2 Dyson V8 Animal Battery Replacement: paso 5, imagen 2 de 2
    • Push down on the red tab on the other side.
    • Pull the motor away from the handle.
    • You may need to hold down the handle while sliding the motor off.
  6. Dyson V8 Animal Battery Replacement: paso 6, imagen 1 de 2 Dyson V8 Animal Battery Replacement: paso 6, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove two 18 mm screws on the bottom of the battery.
  7. Dyson V8 Animal Battery Replacement: paso 7, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove one 18 mm screw on the back of the handle.
  8. Dyson V8 Animal Battery Replacement: paso 8, imagen 1 de 2 Dyson V8 Animal Battery Replacement: paso 8, imagen 2 de 2
    • Slide the battery out from handle.
    • The handle must be held from moving while sliding the battery out.
Conclusión
11 personas más completaron esta guía.
Equipo
Cal Poly, Team S19-G1, White Winter 2020 Miembro de Cal Poly, Team S19-G1, White Winter 2020
CPSU-WHITE-W20S19G1
4 Miembros
10 Guías creadas
5 comentarios
Replacement Vacuum Cleaner Batteries for Dyson V8 Animal
Battery Type:   Li-ion
Voltage:   21.6V
Capacity:   4000mAh
Color:   Grey
Weight:   770.26g
Dimensions: 145.00 x 90.10 x 115.90mm
If you intereted in this battery, please view more info on http://www.drillbattery.com.au/orderbatt...
Drillbatterycomau - Contestar
Thankyou! I'll be able to replace the battery soon.
Olivia Swift - Contestar
This worked for the V7 Animal model just fine. Very easy and clear, thank you!
Katie - Contestar
Thank you. These instructions just helped me to replace the worn out battery on our V8 Animal in 5 minutes! Now it's humming along again with 3 blue bars. Great! (Note: I was concerned I might strip the screw head but I just pressed harder while turning and the screwdriver did not slip. Then I saw that the replacement battery came with four new replacement screws. So, it's all good.)
Neill Graham - Contestar
I have a stripped screw that won't extract. I have already drilled the hole ho so now no screwdriver will work. Any suggestions?
christina - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 39
Ultimos 30 días: 160
Todo El Tiempo: 7,436
