Introducción
If your Dyson V8 Animal’s battery fails to charge or turn the vacuum on, use this guide to replace the battery. The battery is used to power the vacuum. A broken or worn-out battery may fail to turn the vacuum on or charge.
Before using this guide check that your battery does not just need to be charged and refer to The Devices LED Flashes troubleshooting page for more information on troubleshooting your battery.
No special skills are required for this guide.
Before beginning, make sure to turn off the vacuum and disconnect it from any external power source.
Qué necesitas
11 personas más completaron esta guía.
5 comentarios
Replacement Vacuum Cleaner Batteries for Dyson V8 Animal
Battery Type: Li-ion
Voltage: 21.6V
Capacity: 4000mAh
Color: Grey
Weight: 770.26g
Dimensions: 145.00 x 90.10 x 115.90mm
If you intereted in this battery, please view more info on http://www.drillbattery.com.au/orderbatt...
Thankyou! I'll be able to replace the battery soon.
Thank you. These instructions just helped me to replace the worn out battery on our V8 Animal in 5 minutes! Now it's humming along again with 3 blue bars. Great! (Note: I was concerned I might strip the screw head but I just pressed harder while turning and the screwdriver did not slip. Then I saw that the replacement battery came with four new replacement screws. So, it's all good.)
