Introducción
Use this guide to access the vibration motors on DualShock 3 controllers. The two vibration motors are slightly different and thus are non-interchangeable.
Partes
No se especificaron partes.
Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
Lift the battery off the motherboard for enough clearance to access the battery connector.
Pull the vibration motor out of its plastic frame, being careful not to strain the wires connecting it to the motherboard.
10 personas más completaron esta guía.
3 comentarios
That is not how the innards of a European Model DS3 controller are. Wrong guide. Not useful at all
Just because the internals are different and it doesn’t match what you own, it doesn’t mean you need to discredit him…
Davide -
My DS3’s rumble motor died out after 8 years of use so i went out and came to know that there’re many such motors available on market,so i wanna know exact specifications of the rumble motors (both left and right ones) on Dualshock 3 controller,like Voltage,RPM,Dimensions,weight and so.
Please can you provide me the required info ?
