Saltar al contenido principal
Drift HD 720 Speaker Replacement
Qué necesitas
  1. Drift HD 720 Speaker Replacement, Battery: paso 1, imagen 1 de 2 Drift HD 720 Speaker Replacement, Battery: paso 1, imagen 2 de 2
    • Unscrew the back plate counterclockwise until it comes off.
  2. Drift HD 720 Speaker Replacement: paso 2, imagen 1 de 1
    • Push the black battery tab next to the battery to get the battery out.
    • Remove the battery.
  3. Drift HD 720 Speaker Replacement, Speaker: paso 3, imagen 1 de 1
    • Remove six 8mm long Philips head screws with the J0 Philips head from the outer case.
  4. Drift HD 720 Speaker Replacement: paso 4, imagen 1 de 1
    • Remove the back case from the camera body.
  5. Drift HD 720 Speaker Replacement: paso 5, imagen 1 de 1
    • Carefully remove the battery housing from the camera body.
  6. Drift HD 720 Speaker Replacement: paso 6, imagen 1 de 1
    • Remove the wires connecting the speaker to the motherboard from the motherboard, and solder the wires connecting the new speaker to the motherboard in the same locations as the wires that were removed.
Conclusión
Equipo
Baylor, Team 10-16, Williams Fall 2015 Miembro de Baylor, Team 10-16, Williams Fall 2015
BU-WILLIAMS-F15S10G16
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 207
