Saltar al contenido principal
Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement
Qué necesitas
  1. Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement, Battery: paso 1, imagen 1 de 3 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement, Battery: paso 1, imagen 2 de 3 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement, Battery: paso 1, imagen 3 de 3
    • Pull back on the release tabs to disconnect the battery pack from the housing.
    • When installing a new battery, you may need to charge it before using it.
  2. Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement, Motor-Shaft Assembly: paso 2, imagen 1 de 3 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement, Motor-Shaft Assembly: paso 2, imagen 2 de 3 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement, Motor-Shaft Assembly: paso 2, imagen 3 de 3
    • Remove the two screws from the back of the device with the TR10 Torx Security screwdriver.
    • Make sure you have removed the battery before proceeding as accidentally powering-on the device while disassembling is dangerous due to the high-speed components inside.
  3. Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: paso 3, imagen 1 de 3 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: paso 3, imagen 2 de 3 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: paso 3, imagen 3 de 3
    • Lift off the unscrewed plastic cover at an angle, away from the tip of the device.
    • Gently lift the cover. It won't take much force to remove it.
  4. Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: paso 4, imagen 1 de 3 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: paso 4, imagen 2 de 3 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: paso 4, imagen 3 de 3
    • Lift the tip of the motor-shaft assembly gently, then pull the assembly out.
    • The blue battery contact and the spring for the shaft lock button may pop out when you remove the motor-shaft assembly. Make sure to keep track of these pieces, as they are very small.
  5. Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement, Shaft Lock Assembly: paso 5, imagen 1 de 1
    • There are two pieces that make up the shaft lock assembly:
    • The key.
    • The wire ring.
    • The key holds the wire ring in place, and the wire ring secures the motor shaft.
  6. Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: paso 6, imagen 1 de 3 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: paso 6, imagen 2 de 3 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: paso 6, imagen 3 de 3
    • Remove the wire ring from the device.
    • The wire ring may have come out when the motor-shaft assembly was removed.
    • Remove the key from its slot.
  7. Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: paso 7, imagen 1 de 2 Dremel 7300 MiniMite Cordless Shaft Lock Assembly Replacement: paso 7, imagen 2 de 2
    • Ensure that the shaft lock assembly fits together properly when reassembling the device.
    • The notch in the wire ring should fit on the key as pictured.
Conclusión
3 personas más completaron esta guía.
Kat
Miembro Desde 02/10/16
840 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 3-4, Sullivan Spring 2016 Miembro de USF Tampa, Team 3-4, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G4
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 19
Todo El Tiempo: 1,789
