Introducción
If you are experiencing difficulty using your Dragon Touch Y88X Plus tablet due to an unresponsive screen, the issue may result from a cracked or damaged screen. In this case, you will need to replace the screen to restore the device's functionality.
A functional screen is essential for accessing your device and performing various tasks. However, with a damaged or cracked screen, your device may become unresponsive and difficult to use. Follow the detailed instructions provided in this guide to replace the screen of your Dragon Touch Y88X Plus tablet. The guide provides step-by-step instructions, covering all the essential steps involved in the replacement process. This guide lets you quickly fix screen-related issues and restore your device's functionality.
Be sure to power down your device before you start the replacement process. This is important to ensure your safety and prevent any damage to your device.
Qué necesitas
Use a plastic opening tool or spudger to carefully open the tablet's outer case. Start at the corners and work your way around. Be gentle to avoid damaging the case or any internal components.
Locate the ribbon cables that connect the screen to the tablet's motherboard and disconnect them. Make sure to note how these cables are attached so that you can reassemble them correctly later.
To remove the ribbons, flip the black switch where they are connected to the motherboard and gently pull the ribbons out.
Una persona más ha completado esta guía.
