Saltar al contenido principal
Draft Inducer Motor Replacement
Qué necesitas
  1. Draft Inducer Motor Replacement, Draft Inducer Motor: paso 1, imagen 1 de 2 Draft Inducer Motor Replacement, Draft Inducer Motor: paso 1, imagen 2 de 2
    • Start by turning off the flow of gas to your furnace, as well as cutting power to the whole furnace by flipping the service switch to the "Off" position.
    • If your furnace doesn't have a service switch nearby, you'll need to cut power to it at the breaker box.
  2. Draft Inducer Motor Replacement: paso 2, imagen 1 de 2 Draft Inducer Motor Replacement: paso 2, imagen 2 de 2
    • Grab the handle on the front panel marked "Lift" and push up to release the panel. Place it off to the side.
  3. Draft Inducer Motor Replacement: paso 3, imagen 1 de 3 Draft Inducer Motor Replacement: paso 3, imagen 2 de 3 Draft Inducer Motor Replacement: paso 3, imagen 3 de 3
    • The draft inducer is located in the upper-left area of the furnace chamber.
    • Unplug the motor's Molex connector.
    • Your specific furnace model may use a draft inducer with two small connectors on the motor itself, rather than a single Molex connector.
  4. Draft Inducer Motor Replacement: paso 4, imagen 1 de 2 Draft Inducer Motor Replacement: paso 4, imagen 2 de 2
    • Use a flathead screwdriver or a 1/4-inch socket to remove the two screws holding the shield plate to the draft inducer assembly.
    • Remove the plate and set it off to the side.
    • Be sure to keep track of all the screws and bolts!
  5. Draft Inducer Motor Replacement: paso 5, imagen 1 de 3 Draft Inducer Motor Replacement: paso 5, imagen 2 de 3 Draft Inducer Motor Replacement: paso 5, imagen 3 de 3
    • Use a 1/4-inch socket to remove the three mounting bolts securing the draft inducer assembly to the furnace.
    • Support the motor and assembly from the bottom and slowly remove it from the furnace.
  6. Draft Inducer Motor Replacement: paso 6, imagen 1 de 2 Draft Inducer Motor Replacement: paso 6, imagen 2 de 2
    • Use a flathead screwdriver or a small pry tool to carefully pry off the circular clip from the cooling fan.
    • Be careful not to apply a lot of pressure on the fan itself, since it's made of plastic and will break with enough force.
  7. Draft Inducer Motor Replacement: paso 7, imagen 1 de 3 Draft Inducer Motor Replacement: paso 7, imagen 2 de 3 Draft Inducer Motor Replacement: paso 7, imagen 3 de 3
    • Remove the cooling fan from the motor's driveshaft.
    • You may need to apply a decent amount of pressure and wiggle the fan in order to knock it loose.
  8. Draft Inducer Motor Replacement: paso 8, imagen 1 de 3 Draft Inducer Motor Replacement: paso 8, imagen 2 de 3 Draft Inducer Motor Replacement: paso 8, imagen 3 de 3
    • Flip the assembly over and use a 1/8-inch hex key to loosen the set screw securing the blower fan to the motor's driveshaft.
    • More than likely, the fan and set screw will be rusted and seized to the driveshaft. A few sprays of penetrating oil will help loosen it up.
  9. Draft Inducer Motor Replacement: paso 9, imagen 1 de 3 Draft Inducer Motor Replacement: paso 9, imagen 2 de 3 Draft Inducer Motor Replacement: paso 9, imagen 3 de 3
    • Remove the blower fan from the motor's driveshaft.
    • As with the cooling fan, you may need to apply a decent amount of pressure and wiggle the blower fan in order to remove it.
  10. Draft Inducer Motor Replacement: paso 10, imagen 1 de 3 Draft Inducer Motor Replacement: paso 10, imagen 2 de 3 Draft Inducer Motor Replacement: paso 10, imagen 3 de 3
    • Flip over the assembly and use a 1/4-inch socket to remove the three bolts securing the motor bracket to the motor plate.
    • Once the bolts are removed, flip the assembly back over and remove the motor bracket.
    • Once removed, take note of the motor's ground wire, which connects to one of the bracket bolts. Be sure to reconnect it during reassembly.
  11. Draft Inducer Motor Replacement: paso 11, imagen 1 de 2 Draft Inducer Motor Replacement: paso 11, imagen 2 de 2
    • Use a 1/4-inch socket to remove the two bolts securing the motor to the motor plate.
    • Remove the motor bracket.
  12. Draft Inducer Motor Replacement: paso 12, imagen 1 de 1
    • When installing the blower fan onto the new motor, be sure that the set screw on the blower fan lines up with the flat edge of the motor's driveshaft.
Conclusión
4 personas más completaron esta guía.
Craig Lloyd
Miembro Desde 02/10/16
35,546 Reputación
82 Guías creadas
2 comentarios
Thanks for the instructions, very helpful.
Do you know the Inducer motor part number?
Selvan Lingam - Contestar
Good morning, I need the whole unit ( motor, fan, blower fan, ) etc. This looks like same same unit I have but I can't find a model number for this to make sure I purchase the right one for my unit. I have a carrier weathermaker 8000vs looks exactly like the one here can someone please provide some helpful information thanks.
Joshua Thomas - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 22
Ultimos 30 días: 100
Todo El Tiempo: 21,950
