Saltar al contenido principal
Disassembling Olympus Pen E-PL7
Qué necesitas
  1. Disassembling Olympus Pen E-PL7, Battery: paso 1, imagen 1 de 2 Disassembling Olympus Pen E-PL7, Battery: paso 1, imagen 2 de 2
    • Turn the camera upside down.
    • Push the grey tab to the right to open the battery compartment.
    • Pull out the battery.
    • The battery is not shown in these photos.
  2. Disassembling Olympus Pen E-PL7, Back Case: paso 2, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the six 2 mm screws on the bottom of the camera.
  3. Disassembling Olympus Pen E-PL7: paso 3, imagen 1 de 1
    • Remove the two 4 mm reverse threaded Phillips screws from the bottom of the camera.
    • Reverse threaded screws tighten counter clockwise and loosen clockwise.
  4. Disassembling Olympus Pen E-PL7: paso 4, imagen 1 de 1
    • Remove the two 4 mm Phillips screws under the HDMI port cover.
  5. Disassembling Olympus Pen E-PL7: paso 5, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the 5 mm screw near the left hand grip.
  6. Disassembling Olympus Pen E-PL7: paso 6, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the 5 mm screw near the right hand grip.
  7. Disassembling Olympus Pen E-PL7: paso 7, imagen 1 de 1
    • Flip open the LCD.
    • Use a Phillips #00 screwdriver to remove the 2 mm screw beneath the LCD assembly.
  8. Disassembling Olympus Pen E-PL7: paso 8, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the four 6.3 mm screws from the lens mount.
  9. Disassembling Olympus Pen E-PL7: paso 9, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
  10. Disassembling Olympus Pen E-PL7: paso 10, imagen 1 de 1
    • Use tweezers to remove the inner metal ring.
  11. Disassembling Olympus Pen E-PL7: paso 11, imagen 1 de 2 Disassembling Olympus Pen E-PL7: paso 11, imagen 2 de 2
    • Use tweezers to remove the two springs lying beneath the inner metal ring.
  12. Disassembling Olympus Pen E-PL7: paso 12, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the three 5 mm screws.
  13. Disassembling Olympus Pen E-PL7: paso 13, imagen 1 de 1
    • Remove the two 4 mm Phillips screws.
  14. Disassembling Olympus Pen E-PL7: paso 14, imagen 1 de 3 Disassembling Olympus Pen E-PL7: paso 14, imagen 2 de 3 Disassembling Olympus Pen E-PL7: paso 14, imagen 3 de 3
    • Press and hold the lens release button while using tweezers to remove the lens hook.
    • Use tweezers to remove the spring underneath the lens hook.
  15. Disassembling Olympus Pen E-PL7: paso 15, imagen 1 de 3 Disassembling Olympus Pen E-PL7: paso 15, imagen 2 de 3 Disassembling Olympus Pen E-PL7: paso 15, imagen 3 de 3
    • Use tweezers to remove the metal clip from the external flash mount.
  16. Disassembling Olympus Pen E-PL7: paso 16, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the four 4 mm screws from the external flash port.
  17. Disassembling Olympus Pen E-PL7: paso 17, imagen 1 de 2 Disassembling Olympus Pen E-PL7: paso 17, imagen 2 de 2
    • Remove the second external flash clip with tweezers.
  18. Disassembling Olympus Pen E-PL7: paso 18, imagen 1 de 2 Disassembling Olympus Pen E-PL7: paso 18, imagen 2 de 2
    • Remove the external flash port casing to expose five more screws.
  19. Disassembling Olympus Pen E-PL7: paso 19, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the two 6.4 mm screws.
    • Remove the 2 mm Phillips screw.
  20. Disassembling Olympus Pen E-PL7: paso 20, imagen 1 de 1
    • Remove the two 3.8 mm Phillips screws from the sides of the external flash connector.
  21. Disassembling Olympus Pen E-PL7: paso 21, imagen 1 de 1
    • Gently pull the back case away from the camera.
    • Do not attempt to remove the back case, as it is attached to the camera by a ribbon cable.
  22. Disassembling Olympus Pen E-PL7: paso 22, imagen 1 de 3 Disassembling Olympus Pen E-PL7: paso 22, imagen 2 de 3 Disassembling Olympus Pen E-PL7: paso 22, imagen 3 de 3
    • To remove the ribbon holding the back case to the camera, use the pointed end of a spudger to flip back the top bar on top of the ZIF connector.
  23. Disassembling Olympus Pen E-PL7: paso 23, imagen 1 de 3 Disassembling Olympus Pen E-PL7: paso 23, imagen 2 de 3 Disassembling Olympus Pen E-PL7: paso 23, imagen 3 de 3
    • Use tweezers to pull the ribbon out of the connector.
    • Remove the back case.
  24. Disassembling Olympus Pen E-PL7, Disassembling Olympus Pen E-PL7: paso 24, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the two 1.6 mm screws near the left hand grip.
  25. Disassembling Olympus Pen E-PL7: paso 25, imagen 1 de 2 Disassembling Olympus Pen E-PL7: paso 25, imagen 2 de 2
    • Once the screws are removed, use two fingers to remove the metal clip.
  26. Disassembling Olympus Pen E-PL7: paso 26, imagen 1 de 1
    • Remove the 2.2 mm Phillips screw near the left hand grip, holding a second metal plate in place.
    • Remove the 1.8mm Phillips screw.
  27. Disassembling Olympus Pen E-PL7: paso 27, imagen 1 de 1
    • Once the screws are removed, use two fingers to remove the metal plate.
  28. Disassembling Olympus Pen E-PL7: paso 28, imagen 1 de 1
    • Remove the two 4.1 mm Phillips screws near the right hand grip.
  29. Disassembling Olympus Pen E-PL7: paso 29, imagen 1 de 1
    • Use a spudger to remove the three indicated ribbon cables from their ZIF connectors on the motherboard.
  30. Disassembling Olympus Pen E-PL7: paso 30, imagen 1 de 3 Disassembling Olympus Pen E-PL7: paso 30, imagen 2 de 3 Disassembling Olympus Pen E-PL7: paso 30, imagen 3 de 3
    Comprar
    • Use tweezers to remove the plastic cover from the two ZIF connectors in the upper left corner of the motherboard.
    • Disconnect both ribbon cables.
  31. Disassembling Olympus Pen E-PL7: paso 31, imagen 1 de 3 Disassembling Olympus Pen E-PL7: paso 31, imagen 2 de 3 Disassembling Olympus Pen E-PL7: paso 31, imagen 3 de 3
    • Desolder the large ribbon cable from the motherboard at the solder points on either side of its ZIF connector
    • Learn more about soldering with iFixit's Soldering Technique Guide.
  32. Disassembling Olympus Pen E-PL7: paso 32, imagen 1 de 3 Disassembling Olympus Pen E-PL7: paso 32, imagen 2 de 3 Disassembling Olympus Pen E-PL7: paso 32, imagen 3 de 3
    • Remove the 5.2 mm Phillips screw from the top of the right hand grip.
    • Remove the top plate.
  33. Disassembling Olympus Pen E-PL7: paso 33, imagen 1 de 2 Disassembling Olympus Pen E-PL7: paso 33, imagen 2 de 2
    • Remove the sensor assembly from the front case.
  34. Disassembling Olympus Pen E-PL7: paso 34, imagen 1 de 1
    • Remove the two 4.3 mm screws from the front of the sensor assembly.
    • Remove the 6.8 mm screw.
  35. Disassembling Olympus Pen E-PL7: paso 35, imagen 1 de 1
    • Remove the four 1.9mm Phillips screws from the back of the sensor assembly.
    • Remove the 14.5mm Phillips screw.
    • Remove the 3.3mm Phillips screw.
  36. Disassembling Olympus Pen E-PL7: paso 36, imagen 1 de 3 Disassembling Olympus Pen E-PL7: paso 36, imagen 2 de 3 Disassembling Olympus Pen E-PL7: paso 36, imagen 3 de 3
    • Use a Phillips #00 screwdriver to remove the 1.7 mm screw securing the tripod mount to the ribbon cable.
    • Use tweezers to remove the small copper ring underneath the screw.
  37. Disassembling Olympus Pen E-PL7: paso 37, imagen 1 de 3 Disassembling Olympus Pen E-PL7: paso 37, imagen 2 de 3 Disassembling Olympus Pen E-PL7: paso 37, imagen 3 de 3
    • Desolder the red and black wires from the back upper right corner of the sensor assembly.
  38. Disassembling Olympus Pen E-PL7: paso 38, imagen 1 de 3 Disassembling Olympus Pen E-PL7: paso 38, imagen 2 de 3 Disassembling Olympus Pen E-PL7: paso 38, imagen 3 de 3
    • Pull the sensor frame away from the sensor assembly.
  39. Disassembling Olympus Pen E-PL7: paso 39, imagen 1 de 1
    • Remove the 4.4 mm Phillips screw securing the motherboard to the battery compartment.
    • Remove the 3.8 mm Phillips screw.
    • Remove the 3.7mm Phillips screw.
  40. Disassembling Olympus Pen E-PL7: paso 40, imagen 1 de 1
    • Remove the three 3.3 mm Phillips screws at the top of the motherboard.
  41. Disassembling Olympus Pen E-PL7: paso 41, imagen 1 de 1
    • Remove the 3.4 mm Phillips screw from the left side of the motherboard.
  42. Disassembling Olympus Pen E-PL7: paso 42, imagen 1 de 1
    • Remove the motherboard.
  43. Disassembling Olympus Pen E-PL7: paso 43, imagen 1 de 2 Disassembling Olympus Pen E-PL7: paso 43, imagen 2 de 2
    • Remove the battery compartment by hand.
  44. Disassembling Olympus Pen E-PL7: paso 44, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the three 2.3 mm screws from the base of the LCD screen.
  45. Disassembling Olympus Pen E-PL7: paso 45, imagen 1 de 2 Disassembling Olympus Pen E-PL7: paso 45, imagen 2 de 2
    • Fully extend the LCD.
  46. Disassembling Olympus Pen E-PL7: paso 46, imagen 1 de 3 Disassembling Olympus Pen E-PL7: paso 46, imagen 2 de 3 Disassembling Olympus Pen E-PL7: paso 46, imagen 3 de 3
    • Remove the two 2.2 mm Phillips screws located on the back of the LCD screen.
    • Use tweezers to remove the top bracket.
  47. Disassembling Olympus Pen E-PL7: paso 47, imagen 1 de 3 Disassembling Olympus Pen E-PL7: paso 47, imagen 2 de 3 Disassembling Olympus Pen E-PL7: paso 47, imagen 3 de 3
    • Use a Phillips #00 screwdriver to remove the four 1.4 mm screws from the back of the LCD screen.
    • Remove the LCD ribbon cable with a pair of tweezers.
    • The cover may simply fall off after the screws have been removed.
  48. Disassembling Olympus Pen E-PL7: paso 48, imagen 1 de 3 Disassembling Olympus Pen E-PL7: paso 48, imagen 2 de 3 Disassembling Olympus Pen E-PL7: paso 48, imagen 3 de 3
    • Carefully lift the LCD screen up and away from the assembly.
    • Do not attempt to fully remove the screen, as it is attached to the assembly by a ribbon cable.
  49. Disassembling Olympus Pen E-PL7: paso 49, imagen 1 de 2 Disassembling Olympus Pen E-PL7: paso 49, imagen 2 de 2
    • Use tweezers to remove the plastic covering the LCD ribbon cable.
  50. Disassembling Olympus Pen E-PL7: paso 50, imagen 1 de 3 Disassembling Olympus Pen E-PL7: paso 50, imagen 2 de 3 Disassembling Olympus Pen E-PL7: paso 50, imagen 3 de 3
    • Use the flat end of a spudger to flip back the black bar on the ZIF connector.
  51. Disassembling Olympus Pen E-PL7: paso 51, imagen 1 de 2 Disassembling Olympus Pen E-PL7: paso 51, imagen 2 de 2
    • Gently pull the ribbon cable out with tweezers.
  52. Disassembling Olympus Pen E-PL7: paso 52, imagen 1 de 1
    • Remove the LCD Screen.
  53. Disassembling Olympus Pen E-PL7: paso 53, imagen 1 de 2 Disassembling Olympus Pen E-PL7: paso 53, imagen 2 de 2
    • Pull the ribbon cable through the hole in the LCD assembly.
  54. Disassembling Olympus Pen E-PL7: paso 54, imagen 1 de 1
    • Remove the four 2.4 mm Phillips screws from the inside of the back case.
  55. Disassembling Olympus Pen E-PL7: paso 55, imagen 1 de 2 Disassembling Olympus Pen E-PL7: paso 55, imagen 2 de 2
    • Pull the LCD assembly away from the back case.
  56. Disassembling Olympus Pen E-PL7: paso 56, imagen 1 de 1
    • You have successfully disassembled the Olympus Pen E-PL7!
Conclusión
6 personas más completaron esta guía.
Kelsea Weber
Miembro Desde 11/12/15
19,889 Reputación
32 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
136 Miembros
17,299 Guías creadas
2 comentarios
Step 23. You should not be using pointed tweezers here. Or on any of the ribbon cables. They put pressure on the tip only only and could damage across tracks on the ribbon cable. Small long nose pliers with smooth jaws or even small pliers again with smooth jaws. Also for assembly the tweezers would be useless in many ribbon cable reinsertion positions. BTW they are nice tweezers but not for ribbon cables.
jimspc1 - Contestar
I have an EPL-7 in good condition, however, the on/off button has ceased working. It was a slow transition to not working. What could it be and should I spend the 200.00 dollars Olympus wants to service it? Thanks!
Ben Prisk - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 31
Ultimos 30 días: 103
Todo El Tiempo: 10,926
