Saltar al contenido principal
Disassembling Nokia E71 Complete disassembly
Qué necesitas
  1. Disassembling Nokia E71 Complete disassembly, Disassembling Nokia E71 Complete disassembly: paso 1, imagen 1 de 1
    • First remove back cover, battery, chip and memory card .
  2. Disassembling Nokia E71 Complete disassembly: paso 2, imagen 1 de 2 Disassembling Nokia E71 Complete disassembly: paso 2, imagen 2 de 2
    • Remove 4 Torx T5 screws.
  3. Disassembling Nokia E71 Complete disassembly: paso 3, imagen 1 de 2 Disassembling Nokia E71 Complete disassembly: paso 3, imagen 2 de 2
    • Press these four latches (each side has two) to open front cover.
  4. Disassembling Nokia E71 Complete disassembly: paso 4, imagen 1 de 1
    • Carefully remove the front cover with blade tool.
  5. Disassembling Nokia E71 Complete disassembly: paso 5, imagen 1 de 2 Disassembling Nokia E71 Complete disassembly: paso 5, imagen 2 de 2
    • Carefully remove the bottom cover. This cover has no screws, only latches.
  6. Disassembling Nokia E71 Complete disassembly: paso 6, imagen 1 de 1
    • Front cover, rubber keyboard and bottom cover removed.
  7. Disassembling Nokia E71 Complete disassembly: paso 7, imagen 1 de 2 Disassembling Nokia E71 Complete disassembly: paso 7, imagen 2 de 2
    • Remove these two Torx T6 screws at top of the smartphone.
  8. Disassembling Nokia E71 Complete disassembly: paso 8, imagen 1 de 1
    • Carefully remove the assembly. Dont forget to move away the plastic clip holding the assembly down. You can find this in the center on the bottom.
  9. Disassembling Nokia E71 Complete disassembly: paso 9, imagen 1 de 1
    • Base assembly with small connectors and parts.
  10. Disassembling Nokia E71 Complete disassembly: paso 10, imagen 1 de 1
    • Remove the LCD connector.
  11. Disassembling Nokia E71 Complete disassembly: paso 11, imagen 1 de 1
    • Carefully open the LCD and keyboard assembly, and remove keyboard connector.
  12. Disassembling Nokia E71 Complete disassembly: paso 12, imagen 1 de 2 Disassembling Nokia E71 Complete disassembly: paso 12, imagen 2 de 2
    • Both sides of the LCD and keyboard assembly removed.
  13. Disassembling Nokia E71 Complete disassembly: paso 13, imagen 1 de 1
    • I think that two small blocks are the gps antenna.
  14. Disassembling Nokia E71 Complete disassembly: paso 14, imagen 1 de 2 Disassembling Nokia E71 Complete disassembly: paso 14, imagen 2 de 2
    • Both sides of battery - for reference only.
Conclusión
33 personas más completaron esta guía.
4 comentarios
does anyone know if e71 have any battery on board? time and date keep resetting with battery removed.
cyfcyf - Contestar
Yes there is, under the keypad, 3/4 of the way down the left side of looking from the front. It is soldered on to the board so take good care.
Samuel Wyatt -
Hi
I have this phone, but I can not charge it ,Because it has short in board ,plus it very short charger soket (female ), i’m use now extirnal charger only
what can i do ?
Dev Abokhadra - Contestar
Very clear tutorial !
The pictures are well lit, and the instructions are good :)
Thanks !
James Burton - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 25
Todo El Tiempo: 33,522
