Saltar al contenido principal
Dirt Devil Gator Charger Replacement
Qué necesitas
  1. Dirt Devil Gator Charger Replacement, Charger: paso 1, imagen 1 de 1
    • Press the button on the middle of the vacuum by pushing down on it and pulling the device apart.
  2. Dirt Devil Gator Charger Replacement: paso 2, imagen 1 de 3 Dirt Devil Gator Charger Replacement: paso 2, imagen 2 de 3 Dirt Devil Gator Charger Replacement: paso 2, imagen 3 de 3
    • Separate the front and back half of the vacuum.
    • Pull on the back of the vacuum, there should not be too much resistance when pulling it out.
  3. Dirt Devil Gator Charger Replacement: paso 3, imagen 1 de 3 Dirt Devil Gator Charger Replacement: paso 3, imagen 2 de 3 Dirt Devil Gator Charger Replacement: paso 3, imagen 3 de 3
    • Unscrew each individual 13 mm screws with a micro screwdriver from the vacuum.
    • After unscrewing all of the screws, firmly pull on the side of the vacuum to separate the exterior.
  4. Dirt Devil Gator Charger Replacement: paso 4, imagen 1 de 3 Dirt Devil Gator Charger Replacement: paso 4, imagen 2 de 3 Dirt Devil Gator Charger Replacement: paso 4, imagen 3 de 3
    • Pull out the grey switch and circuit board from its slot in the red case.
    • Remove all of the wires from the vacuum to where only the battery and wires are left.
    • Firmly pull out the battery and motor assembly. The circuit board and wires will remain attached.
  5. Dirt Devil Gator Charger Replacement: paso 5, imagen 1 de 1
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 10
Todo El Tiempo: 817
