Saltar al contenido principal
Digitech XC- 5206 Dual Speaker Replacement
Qué necesitas
  1. Digitech XC- 5206 Dual Speaker Replacement, Dual Speaker: paso 1, imagen 1 de 2 Digitech XC- 5206 Dual Speaker Replacement, Dual Speaker: paso 1, imagen 2 de 2
    • Remove the front panel by forcefully placing the flat edge of the spudger in between the panel and the plastic housing.
    • Angle the spudger and use your fingers to pry the panel off.
    • You may need to use extra force.
  2. Digitech XC- 5206 Dual Speaker Replacement: paso 2, imagen 1 de 3 Digitech XC- 5206 Dual Speaker Replacement: paso 2, imagen 2 de 3 Digitech XC- 5206 Dual Speaker Replacement: paso 2, imagen 3 de 3
    • Unscrew all eight 14mm screws closest to the edges of the speaker by spinning a size PH2 screwdriver in a counterclockwise motion.
    • Dislodge face by holding speaker face down. Gently shake or tap front against table to fully remove face.
    • OR grab ahold of the silver tab to pull the speaker face out. This may require force.
  3. Digitech XC- 5206 Dual Speaker Replacement: paso 3, imagen 1 de 2 Digitech XC- 5206 Dual Speaker Replacement: paso 3, imagen 2 de 2
    • Unscrew the eight 10mm screws closest to the center of the speakers by spinning a Phillips screwdriver with a PH2 bit in a counterclockwise motion.
    • Push speaker bulbs forward and out of slot.
  4. Digitech XC- 5206 Dual Speaker Replacement: paso 4, imagen 1 de 2 Digitech XC- 5206 Dual Speaker Replacement: paso 4, imagen 2 de 2
    • Remove green (left) and red (right) wired connection to speaker bulb using a soldering station.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 231
