Saltar al contenido principal
Digitech XC- 5206 Buttons Replacement
Qué necesitas
  1. Digitech XC- 5206 Buttons Replacement, Speaker Buttons: paso 1, imagen 1 de 2 Digitech XC- 5206 Buttons Replacement, Speaker Buttons: paso 1, imagen 2 de 2
    • Remove front panel by forcefully placing the flat edge of the spudger in between panel and plastic. Angle spudger and use fingers to pry panel off.
    • You may need to use extra force.
  2. Digitech XC- 5206 Buttons Replacement: paso 2, imagen 1 de 3 Digitech XC- 5206 Buttons Replacement: paso 2, imagen 2 de 3 Digitech XC- 5206 Buttons Replacement: paso 2, imagen 3 de 3
    • Unscrew all eight 14mm screws closest to the edges of the speaker by spinning a size PH2 screwdriver in a counterclockwise motion.
    • Dislodge face by holding speaker face down. Gently shake or tap front against table to fully remove face.
    • OR grab ahold of the silver tab to pull the speaker face out. This may require force.
  3. Digitech XC- 5206 Buttons Replacement: paso 3, imagen 1 de 1
    • Unscrew upper panel two 10 mm screws spinning a size PH2 screwdriver in a counterclockwise motion.
  4. Digitech XC- 5206 Buttons Replacement: paso 4, imagen 1 de 3 Digitech XC- 5206 Buttons Replacement: paso 4, imagen 2 de 3 Digitech XC- 5206 Buttons Replacement: paso 4, imagen 3 de 3
    • Remove circuit board by pulling straight upwards out of slot.
    • Remove plastic buttons by gently pushing buttons from top of speaker and using other hand to pull from bottom.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 147
