Saltar al contenido principal
Digital2 Platinum Pad 9 Battery Replacement
Qué necesitas
  1. Digital2 Platinum Pad 9 Battery Replacement, External Cover: paso 1, imagen 1 de 1
    • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
  2. Digital2 Platinum Pad 9 Battery Replacement: paso 2, imagen 1 de 2 Digital2 Platinum Pad 9 Battery Replacement: paso 2, imagen 2 de 2
    • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
  3. Digital2 Platinum Pad 9 Battery Replacement: paso 3, imagen 1 de 2 Digital2 Platinum Pad 9 Battery Replacement: paso 3, imagen 2 de 2
    • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
    • Then just remove the backing.
  4. Digital2 Platinum Pad 9 Battery Replacement, Battery: paso 4, imagen 1 de 1
    • The battery is the bigger square object in the center of the device held down by 3 pieces of yellow tape.
  5. Digital2 Platinum Pad 9 Battery Replacement: paso 5, imagen 1 de 1
    • Carefully remove the tape that is holding down the battery.
  6. Digital2 Platinum Pad 9 Battery Replacement: paso 6, imagen 1 de 2 Digital2 Platinum Pad 9 Battery Replacement: paso 6, imagen 2 de 2
    • Lift up the battery it will be glued to the device.
    • Be sure to gently work it to loosen and remove so that you do not damage your device.
  7. Digital2 Platinum Pad 9 Battery Replacement: paso 7, imagen 1 de 1
Conclusión
David DeMeritt
Miembro Desde 03/08/16
637 Reputación
6 Guías creadas
Equipo
Un comentario
Where can one buy the battery?
BedfordGlen Board - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 302
