Introducción
This guide provides detailed steps for replacing the internal battery of the DigiLand DL8006. Required items are listed in the "What You Need" section, followed by step-by-step instructions for replacing the battery as you scroll down.
Qué necesitas
Place the device down on its front with the back facing upward.
Split the two faces of the device with a plastic opening tool to pry the back cover off.
Remove the silver/metallic tape covering the bottom end of the tablet.
Remove the red & blue cord connecting the battery to the motherboard.
Remove the tape connecting the motherboard to the back of the LED screen.
Pry open with a plastic opening tool along the top and bottom edges until the battery is free from the device.
Remove all the remaining tape from the battery.
