Saltar al contenido principal
DigiLand DL8006 Motherboard Replacement
Qué necesitas
  1. DigiLand DL8006 Motherboard Replacement, Motherboard: paso 1, imagen 1 de 2 DigiLand DL8006 Motherboard Replacement, Motherboard: paso 1, imagen 2 de 2
    • Remove the backing of the tablet to reveal the internal components using a plastic opening tool.
  2. DigiLand DL8006 Motherboard Replacement: paso 2, imagen 1 de 1
    • Peel back the metallic tape connecting the motherboard to the tablet body with your fingers.
  3. DigiLand DL8006 Motherboard Replacement: paso 3, imagen 1 de 3 DigiLand DL8006 Motherboard Replacement: paso 3, imagen 2 de 3 DigiLand DL8006 Motherboard Replacement: paso 3, imagen 3 de 3
    • Remove the battery plug from the motherboard.
    • Fingers may be used to gently wiggle the connector out if it becomes stuck.
    • If battery wires are under the ribbon, Do Step #4 first.
  4. DigiLand DL8006 Motherboard Replacement: paso 4, imagen 1 de 2 DigiLand DL8006 Motherboard Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Opening the locking tab of the ZIF connector and carefully remove the upper section of the ribbon cable from the motherboard using tweezers.
  5. DigiLand DL8006 Motherboard Replacement: paso 5, imagen 1 de 2 DigiLand DL8006 Motherboard Replacement: paso 5, imagen 2 de 2
    • Disconnect the three remaining ribbons by opening the locking tabs of the ZIF connectors and gently pulling the cables out.
    • Use tweezers to manipulate the connectors and ribbons to prevent damage.
  6. DigiLand DL8006 Motherboard Replacement: paso 6, imagen 1 de 3 DigiLand DL8006 Motherboard Replacement: paso 6, imagen 2 de 3 DigiLand DL8006 Motherboard Replacement: paso 6, imagen 3 de 3
    • Remove the 3 mounting screws from the motherboard with a Phillips #0 screwdriver.
    • One of the screws is located under a ribbon. You will need to gently peel back the cable to access it (see image 3).
  7. DigiLand DL8006 Motherboard Replacement: paso 7, imagen 1 de 1
    • Gently remove the motherboard from the case.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 12
Todo El Tiempo: 196
