Introducción
Speaker volume is low or audio is distorted are symptoms of a faulty speaker. Please review our troubleshooting page Digiland 10.1'' DL1016 Troubleshooting before proceeding to the replacement. Once you have determined your symptoms and are certain you need a speaker replacement, continue on with this guide.
This guide will help you replace the speaker of a Digiland 10.1” DL1016 device
Qué necesitas
Paso 1 Digiland 10.1'' DL1016 Remove Backing
Aviso: los pasos 1-2 provienen de una guía que está marcada como "En progreso".
Use an opening pick and an opening tool to pry the backing off the back of the tablet.
Pull back the black flaps on the ZIF cable connectors.
Pull the ribbon cables out of the connectors.
Paso 4 Digiland 10.1'' DL1016 Remove Battery
Aviso: el paso 4 proviene de una guía que está marcada como "En progreso".
There is glue that holds the battery down, so carefully pry it open. You may need to use some force.
The speakers are marked in red.
Disconnect the speaker connections.
Remove the speakers.
