Introducción
If your Digiland DL718M tablet has a damaged or unresponsive screen, use this guide to replace the screen of the device.
If you are considering replacing your screen because of unresponsiveness, refer to the DigiLand DL718M Troubleshooting page to find out what could be causing this problem and if it can be fixed without replacing the screen.
This process requires you to remove the back panel of the device and thus expose the motherboard. Be careful when working with an exposed motherboard as you could damage it, if it comes into contact with moisture. It is motion-sensitive, and small aspects can be easily jostled out of place.
Before you begin, make sure to power the tablet off completely and disconnect it from any external power source.
Qué necesitas
Remove back panel by wedging the iFixit opening tool on all four sides of the device.
Una persona más ha completado esta guía.
