Saltar al contenido principal
Dell XPS 15 9550 RAM Replacement
Qué necesitas
  1. Dell XPS 15 9550 RAM Replacement, Back/Underside Panel: paso 1, imagen 1 de 1
    • Turn the laptop upside down.
    • Make sure the laptop is turned off.
    • Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
  2. Dell XPS 15 9550 RAM Replacement: paso 2, imagen 1 de 2 Dell XPS 15 9550 RAM Replacement: paso 2, imagen 2 de 2
    • Open up the information panel door (on the middle of the back side).
    • While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
  3. Dell XPS 15 9550 RAM Replacement: paso 3, imagen 1 de 3 Dell XPS 15 9550 RAM Replacement: paso 3, imagen 2 de 3 Dell XPS 15 9550 RAM Replacement: paso 3, imagen 3 de 3
    • Carefully lift the 2 corners of the back panel close to the hinge upwards, to release the whole panel.
    • Do not force the panel off. If it does not come off easily, try to use a plastic spudger where it is stuck.
  4. Dell XPS 15 9550 RAM Replacement, RAM: paso 4, imagen 1 de 2 Dell XPS 15 9550 RAM Replacement, RAM: paso 4, imagen 2 de 2
    • There are 2 separate RAM sticks.
    • Gently push down on the 2 outside tabs of the RAM stick you want to replace.
    • While still pushing down, gently push the tabs outwards, causing the RAM stick to flip up.
  5. Dell XPS 15 9550 RAM Replacement: paso 5, imagen 1 de 2 Dell XPS 15 9550 RAM Replacement: paso 5, imagen 2 de 2
    • Firmly grasp the RAM stick from the flipped up edge and gently pull out, to release the RAM stick.
Conclusión
5 personas más completaron esta guía.
jbaseballin2
Miembro Desde 10/04/18
117 Reputación
1 Guía escrita
Equipo
UW Stout, Team S6-G1, Ogden Fall 2018 Miembro de UW Stout, Team S6-G1, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G1
4 Miembros
23 Guías creadas
Un comentario
What type ram do you replace it with? Could you post a link?
twrfan - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 14
Ultimos 30 días: 44
Todo El Tiempo: 8,935
