Introducción
Glitching touchpads with erratic cursor movement, not being able to click with the touchpad, and the touchpad being unresponsive are signs that your current Dell XPS 15 9510 touchpad needs replacement.
Qué necesitas
Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
Remove two 4.3 mm screws from the left fan and one 4.3 mm screw from the right fan using a JIS #000 screwdriver.
Using the small battery pull tab, disconnect the battery connector from the motherboard.
Remove the three 4.6 mm screws that secure the heat sink with a Phillips #00 screwdriver.
Lift and remove the heat sink.
Be sure to reapply thermal paste before replacing the heat sink.
Remove the six 3 mm screws securing the touch pad with a Phillips #00 screw driver.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Una persona más ha completado esta guía.
Un comentario
This guide is incomplete. Step 13 shows removing the heatsink, then step 14 is removing the touchpad, but it's a missing a HUGE series of steps in between which is removing the motherboard to access the touchpad. As-is this guide is not usable.
