Saltar al contenido principal
Dell XPS 15 9510 Speakers Replacement
Qué necesitas
  1. Dell XPS 15 9510 Speakers Replacement, Lower Case: paso 1, imagen 1 de 1
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Speakers Replacement: paso 2, imagen 1 de 1
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Speakers Replacement: paso 3, imagen 1 de 1
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 Speakers Replacement, Speakers: paso 4, imagen 1 de 3 Dell XPS 15 9510 Speakers Replacement, Speakers: paso 4, imagen 2 de 3 Dell XPS 15 9510 Speakers Replacement, Speakers: paso 4, imagen 3 de 3
    • Remove the 4 pieces of black tape holding the speaker wire in place.
  5. Dell XPS 15 9510 Speakers Replacement: paso 5, imagen 1 de 2 Dell XPS 15 9510 Speakers Replacement: paso 5, imagen 2 de 2
    • Remove the four 2.5 mm screws holding the speakers in place using a Phillips #0 screwdriver.
  6. Dell XPS 15 9510 Speakers Replacement: paso 6, imagen 1 de 2 Dell XPS 15 9510 Speakers Replacement: paso 6, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Lift the black tape that covers the power supply pin plug.
    • Remove the plug using a small pair of tweezers. Be sure to not damage any wiring.
  7. Dell XPS 15 9510 Speakers Replacement: paso 7, imagen 1 de 1
    • Lift the speakers up from the securing pins.
  8. Dell XPS 15 9510 Speakers Replacement: paso 8, imagen 1 de 2 Dell XPS 15 9510 Speakers Replacement: paso 8, imagen 2 de 2
    • Begin removing the wire from the track on the computer body.
    • Now the speakers will be fully disconnected from the computer.
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
2 personas más completaron esta guía.
Bethany Wright
Miembro Desde 07/13/23
439 Reputación
3 Guías creadas
Equipo
IUPUI, Team 2-1, Harley Summer 2023 Miembro de IUPUI, Team 2-1, Harley Summer 2023
IUPUI-HARLEY-SU23S2G1
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 10
Todo El Tiempo: 263
