Saltar al contenido principal
Dell XPS 15 9510 RAM Replacement
Qué necesitas
  1. Dell XPS 15 9510 RAM Replacement, Lower Case: paso 1, imagen 1 de 1
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 RAM Replacement: paso 2, imagen 1 de 1
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 RAM Replacement: paso 3, imagen 1 de 1
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 RAM Replacement, RAM: paso 4, imagen 1 de 1
    • Using both hands, pull the clips that hold the RAM in place.
  5. Dell XPS 15 9510 RAM Replacement: paso 5, imagen 1 de 2 Dell XPS 15 9510 RAM Replacement: paso 5, imagen 2 de 2
    • Gently, with both hands, pull the RAM up at a 45º angle and take out the RAM.
    • Repeat the same process with the other RAM.
Conclusión
Una persona más ha completado esta guía.
Bethany Wright
Miembro Desde 07/13/23
439 Reputación
3 Guías creadas
Equipo
IUPUI, Team 2-1, Harley Summer 2023 Miembro de IUPUI, Team 2-1, Harley Summer 2023
IUPUI-HARLEY-SU23S2G1
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 10
Ultimos 30 días: 29
Todo El Tiempo: 1,025
