Saltar al contenido principal
Dell XPS 15 9510 Fan Replacement
Qué necesitas
  1. Dell XPS 15 9510 Fan Replacement, Lower Case: paso 1, imagen 1 de 1
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Fan Replacement: paso 2, imagen 1 de 1
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Fan Replacement: paso 3, imagen 1 de 1
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 Fan Replacement, Fan: paso 4, imagen 1 de 2 Dell XPS 15 9510 Fan Replacement, Fan: paso 4, imagen 2 de 2
    • Remove two 4.3 mm screws from the left fan and one 4.3 mm screw from the right fan using a JIS #000 screwdriver.
  5. Dell XPS 15 9510 Fan Replacement: paso 5, imagen 1 de 2 Dell XPS 15 9510 Fan Replacement: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Gently unplug the motherboard fan connector using a pair of tweezers.
  6. Dell XPS 15 9510 Fan Replacement: paso 6, imagen 1 de 1
    • Unplug the motherboard connector on the other fan using a pair of tweezers.
  7. Dell XPS 15 9510 Fan Replacement: paso 7, imagen 1 de 2 Dell XPS 15 9510 Fan Replacement: paso 7, imagen 2 de 2
    • Gently slide and then lift the fans out of their positions.
  8. Dell XPS 15 9510 Fan Replacement: paso 8, imagen 1 de 3 Dell XPS 15 9510 Fan Replacement: paso 8, imagen 2 de 3 Dell XPS 15 9510 Fan Replacement: paso 8, imagen 3 de 3
    • Repeat the previous step and remove the other fan.
Conclusión
3 personas más completaron esta guía.
Bethany Wright
Miembro Desde 07/13/23
439 Reputación
3 Guías creadas
Equipo
IUPUI, Team 2-1, Harley Summer 2023 Miembro de IUPUI, Team 2-1, Harley Summer 2023
IUPUI-HARLEY-SU23S2G1
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 15
Ultimos 30 días: 46
Todo El Tiempo: 1,205
