Saltar al contenido principal
Dell XPS 15 9510 Display Assembly Replacement
Qué necesitas
  1. Dell XPS 15 9510 Display Assembly Replacement, Lower Case: paso 1, imagen 1 de 1
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Display Assembly Replacement: paso 2, imagen 1 de 1
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Display Assembly Replacement: paso 3, imagen 1 de 1
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 Display Assembly Replacement, Display Assembly: paso 4, imagen 1 de 1
    • Remove the four screws (eight total) from each display hinge using a Phillips #00 screwdriver.
  5. Dell XPS 15 9510 Display Assembly Replacement: paso 5, imagen 1 de 1
    • Remove five screws that connect the display using a Phillips #00 screwdriver.
  6. Dell XPS 15 9510 Display Assembly Replacement: paso 6, imagen 1 de 1
    • Carefully remove the display from the Dell XPS 15 9510.
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Austin Sa
Miembro Desde 03/30/22
432 Reputación
3 Guías creadas
Equipo
2 comentarios
Missing a very important step.
Two small screws above the display cable clamp - Step 5 - need to be removed. If you look at the picture in step 5, the far left red/orange circle actually contains one. You can spot it inside and at the top of the of the circle. You can't separate the display assembly without removing those 2 screws.
Joshua Kleier - Contestar
Aren't there any cables that need to be removed?
Ned Eff - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 19
Ultimos 30 días: 60
Todo El Tiempo: 3,624
