Saltar al contenido principal
Dell XPS 15 9510 Battery Replacement
Qué necesitas
  1. Dell XPS 15 9510 Battery Replacement, Lower Case: paso 1, imagen 1 de 1
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Battery Replacement: paso 2, imagen 1 de 1
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Battery Replacement: paso 3, imagen 1 de 1
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 Battery Replacement, Battery: paso 4, imagen 1 de 2 Dell XPS 15 9510 Battery Replacement, Battery: paso 4, imagen 2 de 2
    • Using the small battery pull tab, disconnect the battery connector from the motherboard.
  5. Dell XPS 15 9510 Battery Replacement: paso 5, imagen 1 de 1
    • Remove eight 2.5 mm from around the perimeter of the battery using a Phillips #0 screwdriver.
  6. Dell XPS 15 9510 Battery Replacement: paso 6, imagen 1 de 2 Dell XPS 15 9510 Battery Replacement: paso 6, imagen 2 de 2
    • There are many delicate components in the vicinity of the battery, so be extremely careful removing it
    • Remove the old battery from the laptop.
Conclusión
5 personas más completaron esta guía.
Joseph Remondi
Miembro Desde 03/30/22
290 Reputación
2 Guías creadas
Equipo
Un comentario
XPS 15 9510 states the battery (purchased from ifixit) is FAKE and the battery will not charge.
Jacques Aucamp - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 24
Ultimos 7 días: 79
Ultimos 30 días: 317
Todo El Tiempo: 6,580
