Saltar al contenido principal
Dell XPS 13 9365 2-in-1 Touchpad Replacement
Qué necesitas
  1. Dell XPS 13 9365 2-in-1 Touchpad Replacement, Battery: paso 1, imagen 1 de 1
    • Use a Torx T4 screwdriver to remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9365 2-in-1 Touchpad Replacement: paso 2, imagen 1 de 1
    • Use your fingertips to lift the system badge open and reveal the single case screw.
    • Use a Phillips #000 screwdriver to remove the screw (M1.6x4) that secures the base cover to the palm-rest assembly.
  3. Dell XPS 13 9365 2-in-1 Touchpad Replacement: paso 3, imagen 1 de 1
    • Starting from the front corner of the computer, pry up the base cover using a spudger and lift the base cover off the palm-rest assembly.
  4. Dell XPS 13 9365 2-in-1 Touchpad Replacement: paso 4, imagen 1 de 1
    • Disconnect the battery cable from the system board.
  5. Dell XPS 13 9365 2-in-1 Touchpad Replacement: paso 5, imagen 1 de 1
    • Use a Phillips #000 screwdriver to remove the two screws (M1.6x4) that secure the battery to the palm-rest assembly.
  6. Dell XPS 13 9365 2-in-1 Touchpad Replacement: paso 6, imagen 1 de 1
    • Use a Phillips #000 screwdriver to remove the six screws (M2x3) that secure the battery to the palm-rest assembly.
  7. Dell XPS 13 9365 2-in-1 Touchpad Replacement: paso 7, imagen 1 de 1
    • Lift the battery off the palm-rest assembly.
  8. Dell XPS 13 9365 2-in-1 Touchpad Replacement, Touchpad: paso 8, imagen 1 de 3 Dell XPS 13 9365 2-in-1 Touchpad Replacement, Touchpad: paso 8, imagen 2 de 3 Dell XPS 13 9365 2-in-1 Touchpad Replacement, Touchpad: paso 8, imagen 3 de 3
    • Open the ZIF latch on the touch pad connector.
    • Disconnect and remove the ribbon cable from the touch pad. The ZIF connector latch lifts up to allow its release.
  9. Dell XPS 13 9365 2-in-1 Touchpad Replacement: paso 9, imagen 1 de 1
    • Use a Phillips #000 screwdriver to remove the two screws (M2x2) that secure the touch pad to the palm-rest assembly.
  10. Dell XPS 13 9365 2-in-1 Touchpad Replacement: paso 10, imagen 1 de 2 Dell XPS 13 9365 2-in-1 Touchpad Replacement: paso 10, imagen 2 de 2
    • Lift the touch pad from the inner edge and remove it from the palm-rest assembly.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 31
Todo El Tiempo: 699
