Introducción
In this guide, we will be showing you how to remove and replace the Battery.
Qué necesitas
Paso 1 Back Cover
Aviso: los pasos 1-3 provienen de una guía que está marcada como "En progreso".
Use your fingers or a spudger to pry up the system badge from the bottom of the laptop.
Slide the battery cable connector out of its system board socket.
Remove the screws that secure the battery to the palm-rest assembly.
Lift and remove the battery along with its cable.
2 personas más completaron esta guía.
