Saltar al contenido principal
Dell XPS 12 9250 Battery Replacement
Qué necesitas
  1. Dell XPS 12 9250 Battery Replacement, Removing the Back Cover: paso 1, imagen 1 de 2 Dell XPS 12 9250 Battery Replacement, Removing the Back Cover: paso 1, imagen 2 de 2
    • Turn the tablet over.
    • Remove the screws that secure the back-cover assembly to the display assembly.
    • Using a plastic scribe, pry up along the edges of the back-cover assembly.
    • Carefully, lift the back-cover assembly and turn it over.
  2. Dell XPS 12 9250 Battery Replacement, Removing the Battery: paso 2, imagen 1 de 1
    • Remove the screws that secure the battery to the back-cover assembly.
    • Disconnect the battery cable from the system board.
    • Lift the battery, along with its cable, off the back-cover assembly.
Conclusión
4 personas más completaron esta guía.
Johnathan Hammond
Miembro Desde 02/28/18
45,210 Reputación
408 Guías creadas
Equipo
RampUP America, Inc. Miembro de RampUP America, Inc.
Community
43 Miembros
1,985 Guías creadas
Un comentario
The 4 screws on the edge are NOT phillips head screws. They appear to be Tork.
ponchojack - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 2,478
