Saltar al contenido principal
Dell Vostro 1710 Keyboard Replacement
Qué necesitas
  1. Dell Vostro 1710 Keyboard Replacement, Battery: paso 1, imagen 1 de 2 Dell Vostro 1710 Keyboard Replacement, Battery: paso 1, imagen 2 de 2
    • Make certain that the power to your laptop is off.
    • Press and slide the two buttons outwards and away from the battery.
  2. Dell Vostro 1710 Keyboard Replacement: paso 2, imagen 1 de 1
    • Slide the battery away and parallel from the laptop.
  3. Dell Vostro 1710 Keyboard Replacement: paso 3, imagen 1 de 1
    • Remove the battery from the slot.
  4. Dell Vostro 1710 Keyboard Replacement, Keyboard: paso 4, imagen 1 de 3 Dell Vostro 1710 Keyboard Replacement, Keyboard: paso 4, imagen 2 de 3 Dell Vostro 1710 Keyboard Replacement, Keyboard: paso 4, imagen 3 de 3
    • Use the plastic opening tool to loosen the plastic hinge cover that is located above the keyboard.
  5. Dell Vostro 1710 Keyboard Replacement: paso 5, imagen 1 de 2 Dell Vostro 1710 Keyboard Replacement: paso 5, imagen 2 de 2
    • Remove plastic hinge cover by gently lifting up the cover with a plastic opening tool from one side to the other.
  6. Dell Vostro 1710 Keyboard Replacement: paso 6, imagen 1 de 2 Dell Vostro 1710 Keyboard Replacement: paso 6, imagen 2 de 2
    • Remove the four 3mm Philips #1 head screws.
  7. Dell Vostro 1710 Keyboard Replacement: paso 7, imagen 1 de 2 Dell Vostro 1710 Keyboard Replacement: paso 7, imagen 2 de 2
    • Gently lift up the keyboard to remove.
    • Flip it over as it shown in the picture.
  8. Dell Vostro 1710 Keyboard Replacement: paso 8, imagen 1 de 2 Dell Vostro 1710 Keyboard Replacement: paso 8, imagen 2 de 2
    • Lift the black tab that the keyboard is plugged into.
  9. Dell Vostro 1710 Keyboard Replacement: paso 9, imagen 1 de 2 Dell Vostro 1710 Keyboard Replacement: paso 9, imagen 2 de 2
    • Pull directly outwards to remove the keyboard completely.
Conclusión
Tangxiao Sun
Miembro Desde 03/19/18
496 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 710
