Saltar al contenido principal
Dell Vostro 1710 Heatsink Replacement
Qué necesitas
  1. Dell Vostro 1710 Heatsink Replacement, Battery: paso 1, imagen 1 de 2 Dell Vostro 1710 Heatsink Replacement, Battery: paso 1, imagen 2 de 2
    • Make certain that the power to your laptop is off.
    • Press and slide the two buttons outwards and away from the battery.
  2. Dell Vostro 1710 Heatsink Replacement: paso 2, imagen 1 de 1
    • Slide the battery away and parallel from the laptop.
  3. Dell Vostro 1710 Heatsink Replacement: paso 3, imagen 1 de 1
    • Remove the battery from the slot.
  4. Dell Vostro 1710 Heatsink Replacement, Back Panel: paso 4, imagen 1 de 2 Dell Vostro 1710 Heatsink Replacement, Back Panel: paso 4, imagen 2 de 2
    • Unscrew the eight 6mm screws with a Philips #1 screw driver.
  5. Dell Vostro 1710 Heatsink Replacement: paso 5, imagen 1 de 1
    • Lift back cover from the groove on the left side of the cover next to the symbol.
  6. Dell Vostro 1710 Heatsink Replacement, Fan: paso 6, imagen 1 de 2 Dell Vostro 1710 Heatsink Replacement, Fan: paso 6, imagen 2 de 2
    • Unclip the power supply by pulling the cable directly up and out of the socket.
  7. Dell Vostro 1710 Heatsink Replacement: paso 7, imagen 1 de 2 Dell Vostro 1710 Heatsink Replacement: paso 7, imagen 2 de 2
    • Remove the two 3mm screws located around the edge of the fan with a Philips #1 screw driver.
  8. Dell Vostro 1710 Heatsink Replacement: paso 8, imagen 1 de 2 Dell Vostro 1710 Heatsink Replacement: paso 8, imagen 2 de 2
    • Gently lift and pull to the left until the fan is free from the heatsink.
  9. Dell Vostro 1710 Heatsink Replacement, Heatsink: paso 9, imagen 1 de 2 Dell Vostro 1710 Heatsink Replacement, Heatsink: paso 9, imagen 2 de 2
    • Unscrew the four 8mm screws using a Phillips #1 screwdriver until the heatsink is free.
    • The screws do not come out, only loosen.
  10. Dell Vostro 1710 Heatsink Replacement: paso 10, imagen 1 de 2 Dell Vostro 1710 Heatsink Replacement: paso 10, imagen 2 de 2
    • Lift up on the heatsink to remove it from the laptop.
Conclusión
Una persona más ha completado esta guía.
Tangxiao Sun
Miembro Desde 03/19/18
496 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 294
