Saltar al contenido principal
Dell Venue 8 Speaker Replacement
Qué necesitas
  1. Dell Venue 8 Speaker Replacement, Rear Case/Midframe: paso 1, imagen 1 de 1
    • Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
    • You will hear click sounds as the clips unhinge
    • Remove the back panel of the device.
  2. Dell Venue 8 Speaker Replacement: paso 2, imagen 1 de 3 Dell Venue 8 Speaker Replacement: paso 2, imagen 2 de 3 Dell Venue 8 Speaker Replacement: paso 2, imagen 3 de 3
    • Remove the 14 screws with the T-5 Torx screwdriver. (11 black 3.6mm screws, and three 4.45mm screws)
    • The silver screws are marked with an "S" or a sticker [S1.6(Silver)] See the corrected image
    • 4.45mm Silver screws
    • 3.6mm Black screws
    • Gently snap the perimeter clips open, and remove the internal plastic case.
  3. Dell Venue 8 Speaker Replacement, Speaker: paso 3, imagen 1 de 1
    • Using your plastic opening tool, unclip the speaker connection from the logic board.
    • Caution: Pull directly up, not out, on the connection
  4. Dell Venue 8 Speaker Replacement: paso 4, imagen 1 de 1
    • Remove the speaker by placing using your plastic opening tool in the gap on the top of the speaker and prying it up.
    • The speaker is held on by light adhesive
Conclusión
Andrea
Miembro Desde 02/19/15
1,071 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 9-2, Leahy Winter 2015 Miembro de USF Tampa, Team 9-2, Leahy Winter 2015
USFT-LEAHY-W15S9G2
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 706
