Saltar al contenido principal
Dell Venue 8 Rear Case/Midframe Replacement
Qué necesitas
  1. Dell Venue 8 Rear Case/Midframe Replacement, Rear Case/Midframe: paso 1, imagen 1 de 1
    • Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
    • You will hear click sounds as the clips unhinge
    • Remove the back panel of the device.
  2. Dell Venue 8 Rear Case/Midframe Replacement: paso 2, imagen 1 de 3 Dell Venue 8 Rear Case/Midframe Replacement: paso 2, imagen 2 de 3 Dell Venue 8 Rear Case/Midframe Replacement: paso 2, imagen 3 de 3
    • Remove the 14 screws with the T-5 Torx screwdriver. (11 black 3.6mm screws, and three 4.45mm screws)
    • The silver screws are marked with an "S" or a sticker [S1.6(Silver)] See the corrected image
    • 4.45mm Silver screws
    • 3.6mm Black screws
    • Gently snap the perimeter clips open, and remove the internal plastic case.
Conclusión
7 personas más completaron esta guía.
Andrea
Miembro Desde 02/19/15
1,071 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 9-2, Leahy Winter 2015 Miembro de USF Tampa, Team 9-2, Leahy Winter 2015
USFT-LEAHY-W15S9G2
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 2,462
